Sony kld 32 w 706b
profile.country.RO.title
cosmingpx8
Sony kld 32 w 706b
Hello, does anyone have the Sony KLD 32 w 706b, does anyone know if it works well on the Internet.
Hi there
Im not exactly sure what your asking, however I have not seen mass reports of internet issues on 2014 Smart TVs.  This model uses the same firmware as other 2014 smart tvs, therefore they all perform roughly the same, as well as having the same internet features and applications.
Hope this helps.
Cheers.
timealan
If you're asking "Can you browse the internet?" the answer techincally is "yes", via an Opera browser.
If you're asking "Is the browsing function usable" the answer (in my opinion) is no.  It's really slow and lots of imbedded features aren't supported.
If you're asking "Do the supplied Apps (eg Youtube, Five demand, Iplayer) work ok". I would say "Yes" they work very well and I regularly use the Iplayer on the TV over the OnDemand Iplayer via my Virgin box.
To put that in context I have  a Virgin Cable 50mB line.
Don't knw if that helps.
