Sony Remote Control RM-ED053......
NikolasP
Unfortunatelly i cant find any instructions or manual about this remote control and it has some buttons that i dont understand their purpose.....
My question is about the MEDIA button.......what i can do with it is.......Switch ON the TV from stand by mode....Switch input from HDMI1 to TV.....is that's all about ??????
Thanks.
Hi there
I dont think it does that much to be honest - thats probably why its a small button at the bottom.  According to the manual:
Media - Press to switch the category in the channel selection screen.
See also:
http://pdf.crse.com/manuals/13LW600114/EN/c_selchl_zapui_europe_ga_ch_twn.html
On my remote control (RM-ED044) that button is called "Audio" - Ive NEVER used that button :slight_smile:
Hi there
See also:
NikolasP
Thanks mate....I will take it as a solution..... :thumbsup:
