Sony TV
Sony TV
No power on my Sony KD tv. Both remotes will not turn tv on. Probably the power circuit board but could it be the adaptor? Anyone else had this issue?
royabrown2
Hero
@Toffeeman151
If you have a multimeter, you could measure the voltage at the adaptor output. That will tell you if it is the adaptor that is kaput. But make sure there is power from the mains to the adaptor; socket on, if switched, and take the fuse out of the plug and check it for continuity, make sure it isn’t blown.
