Terrestial input KDL 55NX810
profile.country.tr_TR.title
demird
Can I connect a terrestial antenna to KDL 55NX810 ?
I use it with cable.
I mean change cable antenna with terrestial without a receiver.
etritd
You can unplug the cable antenna and plug in the aerial one. do a channel scanning and you will receive all the available terrestrial channels in your area. For pay TV channels you might need a common interface module and smart-card provided from the broadcaster.
You should know that once you scan for terrestrial channels all the previously stored ones will be deleted.
demird
Thanks.
