trinitron KV-32DS20U
Gbgpb07
Could any knowledgeable folk help me out?
I want to know if this T.V is one of the high end, fine appeture grill capable of displaying high resolutions or if it's a lower end, standard def one.
Any information on this monitor would be appreciated. I did look at the manual on Google but I couldn't find anything to tell me the resolution.
Greg
IamNic
Hello @Gbgpb07,
according to the manual the TV does not support HD-resolution (1280x720p or 1920x1080p) and doesn't feature any connectors required for HD-playback.
You can though purchase a down-converter, which let's you connect devices via HDMI to it and let it down-convert is to a signal the TV can interpret (which then also has a lower resolution).
- Nic
