TV stand info request
Hello Sony world, I've recently moved and lost the stand for my tv it's a Sony KDL-32ex723
I'm looking for a part number for the stand so I can order a new one, any help is gratefully received The Svennster
Hi there
The parts that you require are : HERE
If you have lost ALL of the stand, you will need the following:
  • Stand Screw Set
  • Stand Head
  • Stand Neck
  • Stand Base
Hi there
  • Stand Screw Set
  • Stand Head
  • Stand Neck
  • Stand Base
