usb memory stick problem
riw1246
Cannot use Auto  timer record , the prog i want to record goes into the Error List, the details say that another prog is recording (there is not !)
I think the problem is related to this....when i go into Timer List it displays a prog thats on timer from last March with  red dot  by it , pressing the "record stop" does nothing and cannot scroll to another else on the page.
Have de-registered the USB stick and then re-registered  but its still on the listing.
I can manually set the timer clock to record progs though ,and this method works, but want to just set the normal auto timer.This pic shows the display.
rooobb
A simple reboot (power off button pressed for a long time) should have done the same result without the need to reset everything, good in any case that you solved the issue.
riw1246
Problem solved, did a Factory Reset and it deleted the timed prog.
rooobb
