Videos on usb (kdl-32s5500)
profile.country.it_IT.title
dorian70
Hi from Italy, my name is Doriano. I have a kdl-32s5500. I'd like to see video from the usb door. It seems I can only see mpg format. Does anyone know if there's a way to see even avi or dvd formats? thank you
Tags (3)
Hi there.
Unfortunatley, if you want to play video files that your TV does not recognise, you need to either convert them to a format your TV can play (i.e. Software called Total Video Converter and many others).
Alternatively, you can download Sony's Homestream software, which is based on the Serviio platform. This will enable you to play them directly off your PC or laptop (assuming that your TV is connected to your network).
