Wall mounts older models
Smudgero
Model 46HX823
Movimg this older TV to into a study and going to wall mount. However the screw holes for a bracket seem to be irregular.
horizontal measurement between top two holes is 320mm, but bottom two holes the distance is 300mm. Vertical dimension 150mm.
Has anyone come across this before and if so what bracket can be used.
thanks
5 REPLIES 5
Marino.Manolo
Genius
VESA 46" (2011 KDL-xxHX82x) is 300 mm x 300 mm:
https://www.sony.co.uk/electronics/support/articles/00061343
royabrown2
Hero
Hi @Smudgero
Can you post a picture of the back of the TV, showing that the VESA mounting holes don’t make a rectangle?
Marino.Manolo
Genius
Look the "4 mini black Arrow" in Image... That are the 4 VESA hole...
Smudgero
Marino.Manolo
Genius
