Wi fi connection
keharri8213
Wi fi connection
Hi, does anyone know if a KDL 40W5810 tv can be connected to the Internet wirelessly, is there a dongle or similar available.
arvinO
It seems the w5810 version can only be connected via Ethernet cable, it is the cheapest way to connect a smart tv to the internet, i connected mine using a cat6 cable and it works fine.
arvinO
