wich 3d glasses should i buy??
profile.country.el_GR.title
pouck_75
my tv is the sony bravia kdl 32s2010. Wich 3d glasses should i buy? Would it be enough, or do i need to buy something more than a pair of 3d glasses..?? thank you!!
Hi there
I cannot find anything in your TV's specifications and manual to indicate that you have a 3D TV. Unfortunately, you cannot just purchase a pair of 3D glasses (and transmitter) for it to work. The technology has to be built into the TV first.
Hope that helps.
Hi there
Hope that helps.
