wireless internet problems
profile.country.sv_SE.title
lagtag
I just bought a Bravia KDL40EX720
I can´t get the wireless internet to work.
I says can´t find wireless USB.
i have a Netgear Wireless-N dual band WNDA3100v2.
Can anyone tell me why it doesn`t work, have I bought the wrong thing?
Bjorn in Sweden
Catmambo
It doesn't have integrated Wireless so you need to connect either via Ethenet cable or purchase the Sony wireless dongle.
Hope this helps
Catmambo
Hope this helps
Bravia55HX
Hi lagtag,
the Netgear wireless adaptor you bought will not work with this tv, you need the Sony UWA-BR100 or if wireless is not a priority use a lan cable.
Bravia55HX
i think Catmambo missed the fact that a Netgear wireless adaptor was being used here and thats why it would not work and that his answer does not carry enough merit!
