annulla
Cerca invece
Intendevi dire:
VAIO VGN-FS115B HOTKEY FIX UTILITIES DLL
RISOLTO
profile.country.it_IT.title
edward.benison
Visitatore
Hi to all,
in case you are looking for it, here is the original driver installed in the sony vaio VGN-FS115B to make the hotkeys (Fn) work again if you lost that function after a format and were not able to find them on the website.
The original driver is actually there, just not present in the italian website. It is available on the uk counterpart website.
I hope this maybe be useful to somebody who like me still uses this excellent and unbreakable machine.
Here is where you download it:
http://support.vaio.sony.eu/computing/vaio/downloads/preinstalled/index.aspx?l=en_GB&m=VGN-FS115B
Just download Original Utilities Package and install the utils1 subfolder.
Messaggio modificato da edward.benison
1 SOLUZIONE ACCETTATA
Soluzioni accettate
marcus89
Membro
Hello,
thanks for reporting.
It will certainly be useful to those like you have this problem with this Vaio.
Thanks again.
Bye !
:slight_smile:
1 RISPOSTA 1
marcus89
Membro
Hello,
Thanks again.
Bye !
:slight_smile:
