Hi all,
Does anyone know if it is possible to upgrade a TR1MP to handle 802.11g? Is it easy to change the wireless card and is it available as an upgrade.
Thanks in anticipation
Graham
It's possible but it's certainly not a Sony-recommended upgrade.
If you want to get your hands dirty then fInd out how to do it here: http://www.siliconpopculture.com/reviews_comments/37_0_2_0_C12/
Or, just buy a PCMCIA version.
Actually the easiest solution would be an external card:
PCWA-C300S
