I have been experiencing a few strange seemingly random errors with my laptop.
First, the touch pad is no longer responding to taps, I have had to use the actual button to click things, but moving around and scrolling still work fine.
Second, the backspace button has stopped working, I cant think of anything physical that has happened to make this happen, the laptop hasnt even moved from my desk for the past few weeks, and all the other keys seem to be functioning fine.
And finaly, when booting, it stops at the vaio logo screen and plays a constant high pitched beep until I press a key on the keyboard, then it resumes booting.
I did a system restore to a point where I knew I had none of these problems, but they all still continued, so I done a full factory reset of the whole system and still all the problems continue.
Anyone have any idea, help or advice? Thanks.
Hi SteHarro
I guess if you have done a full factory reset of the whole system and you still all of the problems continue, then it's probably a hardware problem.
Are you still within warranty?
Thanks for your reply Thalamus.
And sadly im no longer within warranty.
