A417 sound card driver prob
biggie944
Hi i had to put windows back in my laptop and i have no recovery disc's the problem is when i try to put the high definition audio drivers back in it says there is a problem and shuts my laptop down can anyone please help.:smileysad: :slight_frown: :slight_frown:
biggie944
biggie944
i fixed this myself you couldn't fix a tyre you are a set of ******* vaio forums are a waste of time u will be better of just doing a google search.dont buy a sony.
Edited: Profanity
William
i fixed this myself you couldn't fix a tyre you are a set of ****** vaio forums are a waste of time u will be better of just doing a google search.dont buy a sony.
Just goes to show the power of a Google search :smileygrin:
Perhaps you will try that first in the future. :cool:
Edited: Profanity
