Hello,
Do you how to access these parameters at boot or under WXP ?
There are some one can change by the "Notebook setup" application or with the power management setup, but if I want for instance define a dailay wake up hour for my laptop, I don't find a way to access the corresponding parameters...
Thank you
Jérôme
The BIOS is locked on VAIOs, so all you see when you press F2 is all you get.
Annoying I know
Annoying I know
Wake on LAN?
Usually this is done by the BIOS.
Contact VAIO-Link
Thank you Kee-lo.
Jérôme
