any help much appreciated, I am unable to play any music...
unclemike
I recently bought a second hand pocket vaio and without instructions, have unplug the machine from the computer before clicking on the "unplug software " and have now lost the ability to play any the music, either on the machine or on the sonic stage.
chris_lewis
Have you tried resetting the player? (small button on bottom of player)
You may also have to do a format & re-transfer to get your PC & player sync'd properly.
Take a look here for more info
HTH
unclemike
yes I have reset the machine and as the machine is second hand the music was not from my PC. looks like a lesson learnt.
