AR21S battery not charging / present
omotn
My problem on my AR21S was that the battery would not charge, now the power meter shows the battery as being not present, even though it is. How do I know if this is a hardware or a software fault, what tests can I run to prove it one way or the other? I would like to be sure that buying a new battery would fix the problem.
Thalamus.
Champion
How do I know if this is a hardware or a software fault. I would like to be sure that buying a new batter would fix the problem.
Hi omotn,
a simple way to check if this is a battery or possible hardware problem is to take your Vaio to a local stockist and ask if you can try another battery in your Vaio..
