Hi - I hope someone has some ideas on a problem with Media Creator 9 which was preinstalled on new AR41L running vista purchased in August 2007. I cant get programme to load properly and get a message 'feature trying to use is on a network resource that is unavailable click ok to try again or enter alternative path to folder containing installation package containing 'Roxio Media Creator Home.msi'. I couldnt find any evidence of the msi file and tried roxio website which says version 9LE is not compatible with vista - so why do sony put it on the machine?? (they dont say its an LE version in their website description of AR41L either but I found some reference on the machine that suggests it is (unless it changes from LE to full version only when fully installed. Any ideas much appreciated - no response from self help entry on sony e support.
i'm really sorry i cannot help you. On my ar41l is working properly. Wish you good luck.
