BATTERIES THAT ARE NOT SONY PRODUCTS?
willDaPimP
HOW CAN YOU DISABLE THE POP UPS THAT TELL YOU THE NEW BATTERY IS NOT AN OFFICIAL SONY PRODUCT? CAN ANYONE HELP
7 REPLIES 7
rich912
Have you looked at your original post?
Go n-éirí an bóthar leat
willDaPimP
i knopw i put that, my friend bought the same battery and managed to disable the pop up that sony run, but he is in australia and i can get him to find out how i do this can you help?
rich912
You are confusing me Will…
I answered the question in your first thread.
The file is called ISBMgr.exe and I think that you will find it locate at Program Files/Sony/ISB Utility/
Click Start > Run and type msconfig and then hit enter. Have a look at the Startup items and uncheck this file, reboot and try the battery again.
willDaPimP
Thanks so much for that, thats me fully powered again smashing thank you
rich912
Your'e welcome Will:smileyhappy:
gnomo74
Just keep in mind that using a battery that was not officially approved/supplied by Sony will void any claim in case of disfunction. As far as I know, it can either work or blow up your VAIO (in case the power cells are faulty/cheap and start leaking).
Caveat emptor
kee-lo_
Yeah I agree, not worth loosing a grand's worth of hardware to save £100
