battery questions
fotiselianos
battery questions
hi there guys
Can I remove the laptop battery while plugged on AC whithout shutting down?
Moreover do you know how should I store the battery.During the week I only need the battery once all the other days I run the laptop 24/7 so I don't want to wear the battery because it doesn't discharge regularly. Can I put the battery on the self of my library for example or in a drawer . Does it need a special place to be stored?
thanx
6 REPLIES 6
kee-lo_
Personally I would shut down before taking the battery out.
You need to keep the battery in a dry place where it's not too hot and not in direct sunlight.
fotiselianos
Thanx for your response
Do you thing it is good to remove the battery considering how many times I use it?(Once a week aproximately) You know batteries are expensive so I don't wont my battery to be destroyed before it's time :slight_smile:
Twisted-Rizla
It's a good idea to condition your battery. Batteries develop a memory and as they get older it is possible to lose a certain amount of this memory . The battery will charge up to the point that it thinks is full up.
It's a good idea to run your battery right down before recharging. This keeps it conditioned.
kee-lo_
This is a common mistake people make these days, new batteries don't have a memory so they don't remember where they were upto so it causes less damage.
Perjescu
Have a look at http://www.batteryuniversity.com/ for good advices.
kee-lo_
