...i have another problem: when i try to start a game, i receive a message error: can't find binkw32.dll .
i copy that on window/system/
but it not run:smileysad:
helpppp!
The zip file containing binkw32.dll should be copied to your \windows\system32 folder if you have Win2000/XP or \windows\system folder if you have Win98/ME.
Click
here for the up-to-date patch. Also, have alook on the site of the game manufacturer to see if there is a patch to fix the problem.
Also worth noting is that some Anti-Spyware programs might regard the bink32.dll as spyware and therefore may conflict.
Please avoid double posting. It stops people like me researching an answer for you only to discover that someone else has already answered your question on another thread.
