Bios Password re-set
Mad_Nad
Hi, I have a sony laptop VPCEB1SOE.
I need yo access the bios, and can not remember the pw, whats the best way to get this re-set with out calling sony and paying 36p per min (RIP-OFF)
any help, advice would be great.
Mad_Nad
rich912
Agreed, and this has been a bone of contention for years:smileysad:
Rich
Go n-éirí an bóthar leat
6 REPLIES 6
rich912
Hi Mad_Nad,
Unfortunately you will need to contact Sony Call Centre to obtain a ‘one time password ‘– They will explain the procedure.  It will be necessary to prove ownership.
This link may be of help…
http://www.sony.co.uk/support/en/topics/solutions/29684
Rich
Mad_Nad
Ok, Thanks
Whats the best number to contact sony, this like does not have a number.
Please give a number that wont cost more this Sony did :slight_smile:
Mad_Nad
Sorry meant Link, not like
rich912
Hi Mad_Nad,
If your notebook is out of warranty then it is the premium rate number - from the UK the number is 0905 0310006. If in warranty then click the support tab, scroll down and select ‘Contact Us’.
Rich
Mad_Nad
ok, that premium number is a ***** right rip-off.  No other comany charge the same as bloody sony do...
Crazy....
rich912
Rich
