BIOS Password?????
NewsomeFiona
BIOS Password?????
Hi all
Ive recently bought my first VAIO. I got it second hand, and it appears to have a BIOS password on startup. The place where I got it from knew this, and supplied me with the password. However, I would like to be able to remove it. Can someone help me please?
My laptop details are:
PCG-K215M
Windows XPSP2
Thanks in advance
Fi :slight_smile:
Kris1990
when you enter the bios the should be a option to change the password
NewsomeFiona
Hi Kris
There is no option, just a password box. Im only assuming its a bios password. It happens before the SONY startup, or windows login.
kee-lo_
Press F2 immediately after entering the BIOS password
