Hi.
My VGN-SZ1HP Bios version is R0063N0(factory version), should I update with R0062N0 version, isn't a lower version? (R0062N0 < R0063N0, right???)
Thank you,
Nuno Cardoso.
Hi Nuno.Cardoso,
Welcome to Club Vaio,
I would agree that with your thinking that R0062N0 would be an older version than R0063N0.
Having read several posts regarding BIOS updates and the problems afterwards, I would also add that if your Vaio is currently running problem free I would not upgrade the BIOS anyway.
You could download the file and keep it safe should you ever require it later though.:smileyhappy:
