BIOS Update
captaintact
BIOS Update
Hello
How do i update the BIOS on a SONY VAIO VGN-S5XP/B
I am using a commercial version of XP and have downloaded the BIOS file but i believe i need some SONY files that use WBFLASH as it will not update. If this so how do it? Perhaps someone could provide a link?
Graeme
rich912
Hi Graeme,
You need to install Sony Shared Library and possibly some of the other Sony Utilities.
The Original Utilities package can be downloaded from here:
http://support.vaio.sony.eu/computing/vaio/downloads/preinstalled/index.aspx?l=en_GB&m=VGN-S5XP_B
Message was edited by: rich912
Go n-éirí an bóthar leat
rich912
Hi Graeme,
captaintact
Many thanks rich912. I was able to update my BIOS following your advice. 🙂
Kind regards
Graeme
rich912
I’m pleased to hear that your problem is sorted Graeme :slight_smile:
