BIOS
profile.country.it_IT.title
forna84
BIOS
How can I access the bios in sony vaio svs1511u9es?
Tags (1)
rich912
Hi forna84,
Normally by tapping F2 at boot. You will find little that can be changed as Sony have locked the advanced settings.
Rich
Go n-éirí an bóthar leat
4 REPLIES 4
rich912
Hi forna84,
Rich
forna84
Thanks rich, It works with f2 you just haave to be very fast pressing the button...
joperez7798
You can use VAIO Care recovery section, for that, let me know if you cannot do it.
knifemotion
I do not see a BIOS Option at the Assist startup, either on shift+ restart, I've tried f2,f3 etc. but no lock.
