BLU-RAY Playback on VGC-RC204
Hello,
I just bought 2 Blu-Ray discs (The Omen 666 from Fox and Elvis Costello from Eagle Vision), and when I try to read them on my VAIO, Windvd BD Edition tells me that it can't read protected BR with my actual screen set-up, and invite me to change it.
I'm actually in 1280x1024 mode, at 60Hz.
What can I do ?
Kind regards,
Virgile
SpaceCowboy1973
You need a Display with a DVI connection that supports HDCP. If you don't want to buy a new one, connect your Display via analog connection to the Graphic Adaptor of your PC.
Hello,
What can I do ?
Kind regards,
Virgile
