Blue 'e' internet icon gone...?
Scottie78
Hi - I've lost the blue 'e' internet icon in my vaio gate. Where can I find it to put back and connect to the internet this way? Thx 🙂
rich912
Hi Scottie78 and welcome.
I don’t use Vaio Gate but the usual way of adding applications would be to drag and drop. So if you have an IE shortcut icon on your desktop drag and drop this onto the dashboard.
Otherwise first create a shortcut by navigating to C:\Programme Files\Internet Explorer and right click on iexplore (.exe). Select Send To and choose Desktop – then proceed as above.
I hope that this helps.
Go n-éirí an bóthar leat
