Hi my blue tooth does not work? it keeps coming up error while trying to save changes? this happens when i select veiw to all on the options screen? what should i do?
Welcome to the forum,
Try this great diagnostic TuneUtilities it give you 30 days to fix any problems and do all it reccommends. If it can't fix it try reinstalling your utilities.exe from VaioLink
