I have recently bought a Logitech Mobile Pro Headset to use on my VGN-T2XP/S.
The vaio has been reset to defaults (today). The Bluetooth headset and notebook are connected (using key mentioned in manual of headset). The problem is that I'm not able to see any Services, which results in not being able to use the headset.
It is possible that the current Bluetooth stack on my PC does not support Bluetooth Audio devices (although being recognised as a headset). Where do I find an update for my Bluetooth stack/software.
ps: using the widcomm files doesn't work. All I need is an update for the Sony Bluetooth stack (I think).
Please reply in complete and understandable sentences that might offer a solution or state a question about information I have forgotten.
bump
I always been under the impression that Windows native Bluetooth drivers did not support headsets, but have a look at this thread. It may or may not be of help to you....
Thanks for your help, but I've already found that 'fix' for myself.
The problem is that I have established a connection, but I'm not aware on how to set my headset as an output device.
