Hello,
Booting process from my new notebook pcg 215m is slow, more than 2 min.
Is this normal and what can I do to improve.
er doesnt take that long for me
Well 2 minute isn't THAT bad, I've had longer than that before. However, go to the Start Menu, and click Run. In the box type "msconfig" (no quotes) and then click on the startup tab in the new box that just opened. Unclick any programs that are running on startup that you feel you don't need (be sure to check first so you don't disable anything important) and then apply the settings. You may also get a small boost by cleaning the resgistry, defragmenting the hard drive and disabling any hardware you know you won't use.
Thanks tygertyger,
Will try the tips you gave me.
Nice day,
Moby
SP2 also lowers bootup times.
Hi kee-lo,
What do you mean with sp2???
Apparently it cuts boot time.
think he means, whats SP2, sorry if im wrong.
sp2 = service pack two, a major update released from microsoft for windows xp which tackles security flaws in the original software
Correct
I personally haven't noticed the reduced boot time. The last thing that loads is my wireless connectivity.
William
