Button config
Sikkel
Button config
I vista installed and it is working fine now, but I noticed that some of the buttons are changed. The "@" is now on the "2", instead on the ' and there are some other changes. The FN options aren't working as well. So has someone got any solution how to change this back.
Thalamus.
Champion
Hi Sikkel,
Is your keyboard set to the correct language.. :thinking:
Sikkel
I set it on "United States", I presume I did it right. What is the correct way to do it.
It depends what keyboard you have.
Have a look at KEYBOARD LAYOUTS - you will need to use IE for this.
It sounds like you have a ENGLISH UK keyboard - try changing to this.
:wink:
