Can I upgrade to a Dual Monitor card for VGN - BX297XP ?
cortala
Hello all
My laptop has an ATI Mobility Radeon X700 which supports connecting two monitors for a bigger view, but not for different images. So, as I now know that a true dual monitor card is what is needed, can I replace/upgrade the X700 - and if so, any recommendations ?
I also use the appropiate docking station which has a spare bay, DVI-D and external monitor support etc.
Thanks for any help :slight_smile: - I did google this but nothing showed.
Hi cortala,
You cannot update the video card and your docking station only allows you to use VGA OR DVI-D - one at a time but not both together.
You will need an external multi-monitor upgrade like this one: -
Matrox DualHead2Go
They also do a triple monitor upgrade.
:wink:
cortala
Thanks for your quick reply, Blencogo.
Hmm, hoped it wouldn't be that expensive though - I'll have a look on the bay and see what I can find. :wink:
