Can't control Vaio FE21M with Sony Ericsson K800i
Cinadus
I've had a Vaio VGN-FE21M laptop since around May or June, and I recently got a Sony Ericsson K800i mobile phone. I was looking forward to using the bluetooth remote control feature to control my Vaio, it detects the computer but for some reason can't control it.. It's fine with sending pictures and music back and forth, so I'm not really sure why this isn't working.
Any ideas? Any help would be appreciated!
Thanks.
Seawit
I'm not sure if i understood what do you intend to do... are you trying to use the bluetooth remote control option to control your computer? If so make sure that you have a remote profile ( in your phone ) that it is compatible with your computer. Maybe you'll need to get the bluetooth remote control program from SE and create a new one compatible with it. :slight_smile:
