cannot update display driver Mobile Intel(R) 945GM Express
diecus
Well, so that's it. The guys from Intel released a new version of the driver but once I'm trying to install it, keeps saying "The driver being installed is not validated for this computer"
Extract from the README.TXT:
January 11, 2008
* NOTE: This document refers to systems containing the
* following Intel(R) chipsets:
*Intel(R) 945G Express Chipset
*Intel(R) 945GZ Express Chipset
*Intel(R) 946GZ Express Chipset
*Intel(R) G33 Express Chipset
*Intel(R) G35 Express Chipset
*Intel(R) G965 Express Chipset
*Intel(R) Q33 Express Chipset
*Intel(R) Q35 Express Chipset
*Intel(R) Q963 Express Chipset
*Intel(R) Q965 Express Chipset
*Mobile Intel(R) 940GML Express Chipset
*Mobile Intel(R) 943GML Express Chipset
*Mobile Intel(R) 945GM Express Chipset ***THIS IS MINE ISN'T IT????***
*Mobile Intel(R) 945GME Express Chipset
*Mobile Intel(R) 945GMS Express Chipset
*Mobile Intel(R) GL960 Express Chipset
*Mobile Intel(R) GLE960 Express Chipset
*Mobile Intel(R) GM965 Express Chipset
*Mobile Intel(R) GME965 Express Chipset
by the way, my VAIO is the VGN-N31M and I am very happy with it but this issue freaks me out becasue is not the first time that I try to update this driver...
Thanks!
5 REPLIES 5
Hi diecus and welcome to Club Vaio.
What Driver Version are you trying to install? XP or Vista.
You will find that Sony block the self-installing .EXE driver download as they seem to think that drivers should be tested by them before release. I would tend to agree if they released them more frequently than on Blue Moons!
Is there a second version of the download in .ZIP format? If so, try downloading the .ZIP file and then right-clicking on it and choosing "Extract All". Extract the files to where you can find them. Go to the extracted files and see if you can find a Setup.EXE - and run it.
:wink:
diecus
My OS is Vista.
Installed driver details:
Driver date: 13/12/2006
Driver version: 7.14.10.1151
Details of the driver that I'd lie to install:
Driver Revision: PV 15.7
Package: 43430
Graphics: 7.14.10.1409
I've already tried that, extracting files and running the setup.exe. Also tried to install it manually from the device manager and updating the driver but still the same results.
Don't know what else to do.
thanks for the prompt answer! :slight_smile:
Sorry, that used to work.
Wait and see if anyone else has a bright idea!
:slight_frown:
diecus
I see...
diecus
Sorry, my mistake. I finally updated it manually using the update driver/have disk....
Thanks anyway.
