Cant see Cd/dvdrom drive Sony VGN-FE31H (not working)
profile.country.fr_FR.title
akramnoura
Hello,
I have  a SONY VAIO VGN-FE31H. I cant see my cd/dvd drive anymore. Im working with Windows 7 - 32bits. When I go in MyComputer I cant see the drive. I have only Local disk C in MyComputer. It is not listed either in the Device Manager.. When I put a cd or dvd in the optical drive, I can hear the cdrom working but nothing happens.. I have try to restore my computer but there are no changes ...
PLEASE HELP...
thanking you guys in advance ^^
rich912
Hi akramnoura,
Is the drive recognised in the BIOS (tap F2 at boot to enter the BIOS)? If not then you possibly have a hardware problem – device or cabling.
Are there any devices listed in device manager as unknown or with a warning symbol – if so is there an error code?
Rich
Go n-éirí an bóthar leat
