Change active video card on VAIO SVF15N1C5E between NVIDEA and Intel
AndreasUK
my Vaio SVF15N1C5E has an NVIDEA GeForce GT 735M and an Intel included card.
1 .Please give me advice how I can check that the NVIDEA card is used.
2. I got problems with video (right hand side is only horisontal lines) in Adobe Flash Player. I try to disable hardware acceleration, but there is no flicker available to do so. I think this has to do with the video card config, but am not sure.
OS is Windows 10, but I think the problem was there also in Windows 8.1 (not 100% sure).
I am very thankful if you could try to help me in any of my two questions.
Thanks,
Andreas.
Tags (2)
Me helped switch off "increase the quality of the video" in the VAIO Contol Center (X-Reality for mobile).
I have this problem too (SVF15N2M2RS).
Unlike you, I have this situation occurs not only in the Adobe Flash Player, but in any player.
AndreasUK
Thank you very much, this helped!
