Hello VAIO Guys.
anybody who know, How I can change the hotkeys for soundlevel?
I don`t like using the "Fn" button! and would like to change so that normal use F3 / F4 is the loudness.
thanks for any idea...and sorry for wonky english.
deVital
Hi devital,
Sorry, I don’t think that this is possible unless you are able to recompile the Vaio Event Service utility which controls this function. Even then you would encounter problems as these keys have default stand alone functions.
okay, thanks for answering it would make it a bit more comfortable but its also okay two use two fingers...
grettings from Hamburg
deVital
