Click to Disc returns message to update Click to Disc Editor when
V-Woman
I try to burn disc.......
Nothing on VAIO Update..........seen a couple of posts on here but not sure if they relate as used to be working perfectly before I recovered my VGN-AR71ZU...
Can anyone point me in the right direction????
Much appreciation for your time. :smileyconfused:Anna
4 REPLIES 4
Hi Anna,
Are you using Windows Vista?
If you look on the downloads website for your model, you will find an update for Click to Disc Editor to version 2.0.03.04150 - try installing that.  It was probably not updated after you reinstalled the OS.
Download it from here under the Windows Vista list of updates: -
http://www.sony.co.uk/support/en/product/VGN-AR71ZU/updates
Any problems, come back here.
:thinking:
V-Woman
For some reason when I checked for Updates for my VGN-AR71ZU Click to Disc Editor previously today none were showing.....but your link showed what I needed but then had the problem of it not recognising that CtoD Editor was installed. I then decided to uninstall and start again so installed from scratch CtoD Editor and did the remaining updates and thought I was getting somewhere when was kicked back with Error Messages...on Click to disc as per snapshot:
Any suggestions?? Baffled.
Seems VAIO Update does not recognise my laptop on occasion either or gives me wrong updates.
Message was edited by: VAIOWomanZ
Looking again, I see there are TWO updates for Click2Disc Editor.  Perhaps you have to install both of these in order: -
1.  Update Ver. 2.0.02.08070
2.  Update Ver. 2.0.03.04150
Only a suggestion as I am as baffled as you!!
:thinking:
V-Woman
Blencogo thank you....yes they were installed in correct order, made sure of that when re-installed....have also checked settings before use but no joy there.....I must be missing something so will just have to keep looking for now until I figure it out but if have no joy will be back...Thanks once again. Anna :smileygrin:
