Click to DVD - Upgrade to new version?
pecany
I'm using Click to DVD 2.6 under Vista with my VAIO but have some problems with it, especially with my external DVD writer: often DVDs are not finished completely, e.g.
'Click to DVD: An error has occured. (ID : 330023)'
or DVDs seem to be burned, but never get ready...
Now I found the information on the Internet that with the new Upgrade 3.0.24.11200 many problems are solved. The Question is: Can I use the version from the Vaio Singapore web site? (here in UK it is not yet available)
The link:
http://www.sony.com.sg/support/download/235839/sectionfirst?site=hp_en_SG_i&subpage=detail
Thanks!
pecany
Tried to install it, but it wasn't possible over 2.6.
Gave up and am using Windows Vista DVD maker now.
Thalamus.
Champion
Hi Alandy,
what model Vaio do you have.?
pecany
Hi
VGN-FE21S
With Regards
