hi all
j'ai essayer d'utiliser les 2 options combiné et divesé ;mais ils marchent pas ,meme si je convert ien atrac !!!
some one has the solution of that ????
thanks !!
ok i see that no one want to reply to my frensh question,
my english is bad but i'm going to try to translate for u,
so
i try to use the 2 options "combined and cut ",they dont work, even if i convert in atrac!!!
i hope that u understund my question
if u want me to translate to german or spanish or something else ,i cant sorry:smileytongue:
Desolé je connais pas le VAIO Pocket, y'a pas beaucoup de gens qui vient ici qu'il utilise.
Donnez-le du temps!
