Connecting Vaio W1 and PS2
orange.ua
Hi.
Does anybody knows the way to connect PS2 to Vaio PCV-W1? I've tried using s-video cable but without any success - computer doesn't see the console.
Any ideas on how to make them work?
THanks.
whsvaio
Hi, If you have GigaPocket with your W1 you should be able to view the PS2, you'll need to select the appropriate connection ie. S-Video or composite( A / V in). Hope that helps.
orange.ua
well... it let's select only one source, but it works!
thank you!!!
