dead laptop...
tom_wilde
dead laptop...
:cry:
two weeks in.. it's died...
simply won't power on - I'm really losing faith in vaio here.
anyone?
15 REPLIES 15
tom_wilde
oh. it's a VAIO FS315S btw...
kee-lo_
If it's 2 weeks old you have time to take it to the retailler.
They should replace it or contact VAIO-Link for you
William
Consider yourself lucky - They usually die just out of warranty (Well most GRX's did anyway)
martijnaikema
I have the same problem.
Really frustrating.
I have it with the FS315E.
IckleAndy
:slight_frown:
Same here, a A417M. Monday it was working great and now it refuses to power up. No indicator lights at all - not good. Managed to last 3.5 months though.
ParmiD
I have a TR5MP which I bought in 2004. It was working yesterday, and then after I shut it down it refuses to power up again. With the mains plugged in, the battery charging LED isn't flashing either - which makes me think it's a fuse or something inside the unit. Does anyone have any tips on how one might try to figure out and fix summat like this?
cheers
comixxx
me too , Vaio FX605... nothing goes... :cry:
mutungi
If you guys have upgraded the memory, then remove the upgrade chip and try again.....it should work now.....mine did!
fangorn
Same problem with a A397XP. And it's for professional usage! Lost all my emails... Still under warranty for 4 monthes. Sony e-support said to me that this is the motherboard.
