Deleting Playlists
blueseattdi
Deleting Playlists
I am trying to delete songs from the playlists but do not get the remove song option as indicated on page 21 of the instructions. The only way I can do it is to delete particular albums from the Pocket (so the associated songs get removed) and then retransfer the album back to the player. Surely there is a more straightforwrd way!:smileyconfused:
WhiteRider
Hold down one of the middle buttons to get the advanced options on screen, and the remove from playlist icon should be there.
