Dirt Stuck under keys
SamN
Hi I have a VGN-FE41M and there has been some stuff stuck under a key for a while. I ahve managed to get it away from whatever key by blowing underneath the key an dislodging it. That is very annoying though, and there is also some suck under the left side of the space bar which will not budge.
Any ideas short of opening it up. I really hate opening laptops as it is always an unknown venture for me.
I would prefer not to pay someone else to do this tho...
Thanks in advance! (and my to my other thread coming imminently)
Thalamus.
Champion
Hi SamN,
welcome to Club vaio.. :slight_smile:
You could try clearing the dust/dirt from under your key with compressed air, you should be able to buy this from your local PC shop.
