Hi there ive just reicently bought a Segate Momentus 100GB 7200 HD for my S2XP which had a hard drive failure. Can anyone let me know (before i strip all my machine) if this will work with no worries on my 1.5 yr old Sony VGN-S2XP?
thanks in advance
Regards
Barrie
Hi Barrie,
Your S2XP has an IDE interface and I think it will require a Parallel ATA drive.
You probably need THIS ONE - not the one with 'S' on the end!
