HI, I have my A217S for a couple of weeks and I've a problem with my dvd player. I can the sound but no images!
Any idea ti fix that?
many thanks
younouss
yep I did that! but it doesn't work. I updated the mpeg encoder driver and ATI driver too...:smileycry:
Does this happen with every disc you try and play or just certain ones?
Which program are you using to play DVD's? Try reinstalling WinDVD.
I try to reinstall windvd but it doesn't work. Finally, I decided to remove all software related to dvd (nero and dvd shrink) and now it works. I don't understand why but it works!
anyway I suspect nero is the cause of my problem.
I didn't trys dvdshrink with alcohol but try that later
Alcohol 120% can stop the use of the eject key.
