E Series BSoD On Shutdown
HorusVrae
Hey everyone. I bought my E Series Vaio three weeks ago. The Spec is:
i3 Processor
4gb ram
intel 3000 hd gfx
15" screen
500gb hard drive
As a Mac-windows switcher im very impressed with it.
A Problem has developed over the passed few days in which it will boot and run fine, play Eve online perfectly (at an impressive 60fps!) surf the internet, work with Dreamweaver, anything i want it to, until i want it to shut down.
It will run through the Shut down process and then as the screen goes black it comes back with a Blue screen of death telling me that windows was shut down to avoid damage to my computer and then it attempts to dump the memory. Both times this has happened i have forced a power off by holding the power button.
On the next boot the machine starts up normally only to tell me that Windows has recovered from a serious problem.
Any ideas what could be causing this? Should i be contacting Currys (where i purchased it from) for support?
cheers,
~horus
Tags (2)
mahmoodbutt
Hey Horus,
Have you found the resolution????, cuz i m having the same issue. My laptop specs are quite similar.
Model no: VPCEH1L0E
i3-2310
4GB RAM
320 GB HDD
Sony support team!!! please need to know the solution.
